obd2tool
Sign in to follow this
  • entries
    2
  • comments
    0
  • views
    796
Comparation Autel MaxiSys MS906 VS MS906TS VS MS906BT
Divad968
Autel MaxiSYS MS906 VS AUTEL MaxiSYS MS906TS VS MS906BT have the same function, but also have many different as follow:
A:Function: MS906<MS906BT < MS906TS
B.MS906TS is added TPMS function based on MS906BT.
C.MS906 has the same apperance with MS906BT, But MS906BT has a few advantage than MS906:
1. MS906BT is installed Bluetooth, allowing diagnosis wirelessly.
2. MS906BT’s diagnostic coverage includes premium vehicle brands such as Maserati and Bentley, which would be required for high-end service shops.
3. MS906BT supports oscilloscope and digital inspection camera add-ons which are not supported by 30% Discount Products MS906.
4. Finally, MS906BT has the capability to perform coding for covered vehicles.
The MS906BT have all the capabilities of the maxisys mini ms905 as far as vehicle coverage and capabilities for codes, live data, actuation tests, adaptations and ECU coding .comparing the new MS906BT to the MS905 and they are similar in size but the MS906BT seems to have improvements such as faster processors, slightly larger screen, twice the battery capacity and better camera
MaxiSys MS906BT is the latest addition to the MaxiSys product line of advanced wireless diagnostic devices. The device is based on the Android operating system featured with the best possible coverage of OE-level diagnostics and ECU coding capability. Utilizing the powerful Exynos 5260 6-core processor (1.3 GHz quad-core ARM Cortex-A7 + 1.7 GHz dual-core ARM Cortex-A15), an 8” capacitive HD touch screen, and long-distance wireless communication, the MaxiSys MS906BT efficiently provides comprehensive vehicle diagnostics and analysis.
0 Comments
