cxu low air and shut down buzzer not working
.most newer units have the buzzers built into the dash can't mess with it
if the low air has quit you may have to add in a low air sensor and a seperate buzzer or buy a new dash for an outrageous amount
cheapest to add on!
Edited by fjh
Im liking the add on low pressure sensor and buzzer. I have also lost the beep that sounds when you cycle key switch on, which is the same beep that lets you know cruise is set, or when idle shutdown is about to happen etc. Is this same beep tied into the low air warning buzzer just different audible sounds?
  • 3 months later...
