Air Leaking From Treadle Valve Exaust Line
Mebsrajan
Hi Guys I Have Mack Vison 2004 The Problem I'm Having is First it was small leak from treadle valve then I changed the valve put the new one in but the problem is still there but worst now all the air is leaking from the same place. if i press and hold the padel the air will build up to 70 and stay as soon as I leave the padel all the air leaks from treadle valve exhaust line .  Help
Been there, done that. Usually the treadle is a real pain to change and then you find out that wasn't the problem.
I don't recall what the solution was but you have another valve sticking somewhere causing it to back feed through the treadle valve.
