Sign in to follow this
Followers 0
LocomotiveBreath
B20 Pickup Build
10 posts in this topic
I am going to build a B20 pickup and wanted to get some opinions on the bed lines I am thinking about. I will be fabbing the bed up from scratch so I am only limited by my wallet and time. I found a Google picture of a B20 fire truck then did my rookie version of photoshop to get an idea of how the finished version would look. My truck will go back dark green, not red, but I'm thinking the bed lines will be very similar to the picture. What do you guys think?
Share this post
Link to post
:mack1: Looks like an awful straight truck to chop down! Terry
Share this post
Link to post
Not going to chop up the Mack, just fabricating a bed for it and it will be removable if needed. The B20 will keep the original cab, chassis, and running gear, although it will probably end up with more HP than it originally had. I was just trying to get an idea of how it will look when finished.
Share this post
Link to post
The best pick-up bed that I've ever seen on a "B" was from a late '60s till mid '70s Dodge stepside. They had the cool big round fenders that go sweet with the B lines. Even if you copied them to use on your longer frame they should be easy to roll out.
Share this post
Link to post
Thanks Greg, those do have a shape that might look good on a B pickup. I'll have to improve my photoshop skills to test the theory.
Share this post
Link to post
LB, good luck with your project. I found this photo of a pickup truck that Mack actually did build for a short while in the mid 30's.
Share this post
Link to post
Thanks, I'll bet those old factory built Mack pickups are worth a fortune.
Share this post
Link to post
They were actually built by the White Motor Company under contract by Mack.
Share this post
Link to post
Thad; REO was the subcontractor for the Mack "Jr" series of small truck.
Share this post
Link to post
Doh! Thanks for the correction Rob.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
