how do I set the clock on my Mack radio?
Um..........hammer?
Post a pic of your radio. I am sure it is manufactured by an OE that supplies other truck companies. Have you contacted your local Mack dealer?
Here is something I found on the internet, hopefully it will help.
http://www.ehow.com/how_7447576_set-time-mack-truck-radio.html
Ken
I don't think your '06 has the newer interior. But...... I only found out recently the Newest CXU's I have (2013's) that have the dash cluster display screen is where you set the time on the radio with the steering column stock selector. The time can only be reset while the truck's parking brakes are on and when you set the in dash display, it automatically sets the radio time.
My 2011 gu has a clock in the display at the top of the dash (set thru the stock and menus as stated above), and the one on the radio (set thru the menu on the radio, but I believe it to be a different radio than the one the op is referring to)
  • 8 years later...
9 hours ago, Nobody454 said:
my kw t880 has 2 clocks, radio and by the speedo...both set differently, and both keep different time...in 3 days they are already 3 minutes apart 🤮
my new truck is not quite that bad. so far it has only gone 1 minute off in 4 weeks. (yesterday)
the 2020 T880 would go 1 minute off every 5-6 days.
On 11/1/2022 at 11:52 AM, Luis Alvarez said:
How to set the time on a 2014 Mac GRANITE radio
Press knob to show “audio control menu”. Rotate knob until “clock” is shown on the display and press the knob to enter “clock menu”.
