Sign in to follow this
Followers 0
rockhauler
High Oil Temp
5 posts in this topic
I got a 2006 vision cxn613 with a ac-460 and lately my oil temp is way higher than normal(normaly at 190 F loaded and now it goes up to 225 F loaded) but coolant Temp is still normal. I'm running rotella 15w40 and did a oil&filter change and still having problem.
Before I get into buying and changing the oil coolant I would like to here a second opinion.
Share this post
Link to post
Oil coolant?
I would try the oil temp sensor first if the change in temperature is sudden with all other parameters remaining the same.
Share this post
Link to post
Oil coolant?
I agree with rob, might try a infrared temp gauge to check and verify it is actually that temp
Share this post
Link to post
Sounds like the oil cooler is plugged, but it's not going to hurt anything to check the temperature as suggested first.
Share this post
Link to post
The oil cooler inlet screen could be plugged, needs to be removed and cleaned or replaced every year or so.
oil cooler inlet screen.pdf
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
