Sign in to follow this
Followers 0
KTRON
Bendix Air Compressor Rebuild Kits - Where To Buy Parts?
5 posts in this topic
I bought an air compressor for my Detroit Diesel 6V53T. (Bendix Westinghouse TU-Flow Model 501)
It is a power take off model which bolts to the accessory cover on the flywheel housing.
While cleaning up the pump I noticed that the air cleaner was shot. It looked like ground up carbon.
I cleaned the inside of the housing, and now I need a new air filter.
When I removed the head from the pump, I noticed that the pistons were stamped "0.10 OS"
The cylinders are scorn, so maybe I need to have the cylinders honed, and new rings installed.
I would like to buy a gasket kit/filter replacement parts for the pump I have, but I do not know where to find them.
Here is the information I have:
Model: 501
Serial: K2494
Part: 286538
The air filter housing has number: 236594F
The head has a casting number of: 294146
The block has a casting number of: 249960
Pictures:
th_SL735454.jpg th_SL735455.jpg th_SL735457.jpg th_SL735459.jpg th_SL735458.jpg th_SL735460.jpg
Any ideas???
Chris
Share this post
Link to post
Model: 501
Serial: K2494
Part: 286538
Pictures:
Any ideas???
Chris
Call these guys. They'll have parts and expert advice for anything you would require.
http://rebuildersenterprises.com/contact_us/contact_us.asp
Share this post
Link to post
The best thing for you to do is exchange the compressor because if you can find parts it will cost you more to repair it than a new one will. Seen guys play with them for long time when its cheaper to exchange.
Share this post
Link to post
It pumped air just fine before I removed the head for inspection.
I have been completely restoring all of the parts on my engine, and this pump was just next on the list.
The pump shares the same oil as the engine. After doing a full rebuild, I cant take any chances running a pump which could have loose metal in it.
Thankfully there was none, crankshaft and everything looked good nice and clean.
The pump will only be used to shift the transmission I will be attaching to it, and possibly air horns
It will not be running brakes of any kind, I dont have a CDL
I see a field maintenance kit for one of these on ebay for real cheap. It has all of the parts I need other than new piston rings.
If I cant find them, I am sure new rings can be cross-matched from small gasoline engines...but thats a last resort
Chris
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
