Sign in to follow this
Followers 0
DMorgan
Wedge Brakes
17 posts in this topic
Hey Everybody,
I just bought a truck that has wedge type brakes on th rear axels. I was wondering if anybody has messed with them before and also how reliable are they and how well do they work? My truck has four brake pods on each rear axel,(two on each side). If anyone has any advice, I'd appreciate it.Thanks,
Daniel
Share this post
Link to post
Hey Everybody,
Daniel
Most will say they are garbage and they are probably right. I have a 73 RL797L with them on front and rear and they work perfect. Get a book and take the hubs apart making sure the adjusters are greased properly and not frozen, then adjust them as they should be and they will work well for you.
Share this post
Link to post
Had a tractor with wedge brakes once. Just had to be sure it had a trailer behind it with good enough brakes to stop the whole rig!
Share this post
Link to post
Thanks Rob & David for your input. We'll be going through he whole truck and was wondering if they would need to be replaced with something better. Thanks, Daniel
Share this post
Link to post
http://www.axletech.com/service_manuals/pdf/standard/mm4r.pdf This is a manual you can read some if you go into them. If you do them right and make sure the adjucters are not bad and then clean them and use the grease that rockwell makes with new seals on the plungers you will be able to use them for many miles. Dont use any grease unless it is a water proof grease. Make sure the drums are good and smooth and no grooves in drums or on the shoes. Adjust them up be for you mave the truck If you dont do this you sre only playing with your self.They dont have a lot of travel so get them up almost draging to start with.They in most cases are self adjusting.
Share this post
Link to post
Theakerstwo, Thanks for your reply, that website should help us a lot. Thanks, Daniel
Share this post
Link to post
As one of the BMT Guru's stated once:
"If you push on the brakes and you stop - - - You don't have wedge brakes"
I still laugh about that!!!!!
Most funny!
Packer
Share this post
Link to post
Most funny!
Packer
That RL of mine you gotta be careful when stepping on the brake pedal unless you like the taste of laminate glass because a lighter man would surely kiss the windshield if they were to plant the pedal. The combination of my bloated carcass and steering wheel brake belly keeps me from doing it. I've had all the wheels and drums off and everything is new inside the hubs and is adjusted as per the manual. I guess as Glenn said they'll serve a long time if maintained properly but are a nightmare if not.
Share this post
Link to post
i drove a three live axle dm it was a red bird concrete truck that bill revel put a dump bed on 20 ft. shot rock box 37,000 empty and clean. he built 3 of them, 237,18 speed quadroplex, my sholder hurts still aafter 20 years. it had wedge brakes it would slide every wheel with 40 ton on it,gvw around 120,000. they where great. but the machanics there did not know how to work on the wedge brakes,or didn't want to spend the time, so in a short time, hauling that kind of loads, they didn't last long. if you went from 4th to 3rd in the main box to hard, they would break the input shaft on the front axle. between that and the wedge brakes they where parted out.
Share this post
Link to post
wish i had pictures they where so cool, when i was in my twenty's
it would make for a very long day in my 40's
Share this post
Link to post
i have never seen cam brakes that would do that!
Share this post
Link to post
this might be a stupid question but what is the diff about the wedge brakes? i got a cut off for extra parts for my truck and the cams and shoes are difrent than the ones on my truck the cams on the cutoff look like Z's and the shoes have a flat spot on them instead of rollers. are these wedge brakes? joe
Share this post
Link to post
Most funny!
Packer
I remember: If the truck does not stop you have wedge brakes. If it stops you may or may not have wedge brakes.
Share this post
Link to post
Old joke of mine. Wedge brakes never wear out. Why? The shoes never touch the drums. Well that is almost true cause like Rob said if they are done the right way they can be a good brake. They do not require much voluminof air because of the small cans on them.But when they stop adjusting then get them down and repair the adjusters.CF used them big time on tractors and trailers.
Share this post
Link to post
No. I've heard them called flat cams or z cams. Wedge brakes have a wedge (instead of the cam) located between the shoes.
Share this post
Link to post
Keep us guys employed getting them backed off to get the wheels off anyway Glenn! pat.gif
Share this post
Link to post
Thanks everybody that replied to my question. Sorry tht I didn't get back to you all earlier but I had some prblems with my computer. Thanks Again for all the help. Daniel
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
