Look at it this way, 1)You're probably never going to part with it, 2) if it wasn't rust free than more than likely it wouldn't worth doing , You don't like the window entry so why live with it when you have an option, 4) if and it's a big if you wanted to put it back the rear cab panel is available.
Good points all the way around there.
Yep,the ones on a Superliner are a little taller than on a R model for some reason,but basic design is the same
Gosh, I'm having a hard time seeing how there's room for those brackets between the sleeper and the cab. Kind of a tight fit eh?
{l@@k at that, an even 6000 posts:)}
Thats a Bentz on your white B61?
Yes.
I redid the front of the bunk to match what I did to the cab.
I say cut it up and make it work. Unless you are trying desperately to "keep it original as possible".
The day I put the hole saw to the back of my cab.....whoooeeeee...........ain't no going back now.
