Air conditioning leaking water in superliner
insulated bib overalls too.
Have some gloves that are good to -20. Used them when I worked at the ice cream distributor
just need to keep this in my mind and I will stay plenty warm
I had that happen on mine. Blowing back may work but if it blocks again, you'll have to clean the drain pan under the cores. If there is a lot of dirt in it, it will block back up again.
It's been a while since I did it, I think the cores have to be removed with it. But that does make it easier to clean everything. Over time from condensation, dust gathers in the fins and air flow is decreased. Then it finds it way into the drip pan and sometimes blocks the drain.
