Gold bulldog question...?
I'm thinking Muratic acid should strip the chrome from the dog. Pretty sure that is what is on the tank at the chrome plater we use at work(industrial chrome, not show chrome). Put in it a jar, let it sit and check it occasionally and see. Likely won't take the nickel and copper off though.
I just talked to my Chrome Plater. He could not understand why your plater would not strip it for you, majority companies do. They can get the old plating off for themselves and start from a new base, then start layering it. They are responsible for how it turns out for the customer. Only suggesting........find another Plater. Oh! one more thing. If it is a Gold Plated part then it will be a copper base only and layered until smooth enough to Gold Plate. To keep it looking new longer, use a clear urethane or the Gold will rub off easier. If you can still find it use Krylon Crystal Clear it is cheaper than the urethane automotive clear.
Happy Hunting!
mike
I think I saw a new Mack R model grille at Winrock truck parts in the warehouse, cant be sure but it seems like I did.
