are the throttle and choke shafts still fitted? or are they wobbly? if shafts are tight the carb should be able to be kitted if memory serves the model of the carb is stamped in the mounting flange then a call or search should get a kit.
Daytona Parts,
Will rebuild, or sells kits.
Ron
World Class Parts Since 1974
Whats Here?
Find Your Carburetor.:
Our website to add over 100,000 records of carbs, kits and parts.
Use this page to search for your carburetor either by you auto and year or by the carb number .
More Info:
We supply kits and parts for:
  • Automobiles
  • Trucks
  • Marine
  • Industrial
  • Small Engines
Links:
arrow.gifOn-line sales policy
arrow.gifORDER FORM
arrow.gifRestoration Quote
Links:
arrow.gifORDER FORM
E-mail: Send us an Email Our Phone:
386-427-7108
Our Fax:
386-423-8528
Our Contact Form:
Click Here
Find your Carburetor or Repair kit
Select the Auto Make then the Year. Select a MakeAERO COACHALFA ROMEOAMCAUBURNAUDIAUSTINAUTOCARAVAILABLEBIEDERMANBMWBORGWARDBRISTOLBUICKCADILLACCARTER UNIV. CARBSCHECKERCHEVROLETCHEVROLET TRUCKCHRYSLERCITROENCORBITT TRUCKCORDCROSLEYDAIMLERDART TRUCKDATSUNDAY-ELDER TRUCKDESOTODIAMOND T TRUCKDIVCO TRUCKDODGEDODGE TRUCKDUPLEX TRUCKDUSENBURGEDELBROCK CARBEDSELESSEXFAGEOL TRUCKFEDERAL TRUCKFIATFLXIBLEFORDFORD TRUCKFORD (ENGLISH)FORD (FESTIVA)FORD (GERMAN)FWD TRUCKGEOGMC TRUCKGOLIATHGOTFREDSON TRUCKGRAHAMGRAMM TRUCKHAHN TRUCKHAYES TRUCKHILLMANHOLLEY UNIV CARBSHONDAHUDSONHUG TRUCKHUPMOBILEHYUNDAIIHC TRUCKIMPORT HI-PERF CARBSINDIANA TRUCKINNOCENTIISUZUISUZU TRUCKJAGUARJEEPJENSEN-HEALEYKAISER-FRAZERKENWORTH TRUCKLAFAYETTELANCIALASALLELINCOLNLOTUSMACK TRUCKMARMON-HERRINGTONMAZDAMAZDA TRUCKMERCEDES-BENZMERCURYMGMITSUBISHIMITSUBISHI TRUCKMORELAND TRUCKMORGANMORRISNASHNASH TRUCKNASH METRONISSANNISSAN TRUCKOLDSMOBILEOPELOSHKOSH TRUCKPACKARDPANHARDPEUGEOTPIERCE-ARROWPIERCE-ARROW TRUCKPETERBILT TRUCKPLYMOUTHPLYMOUTH ARROWPLYMOUTH CHALLENGER (IMPORT)PLYMOUTH CHAMPPLYMOUTH COLTPLYMOUTH CRICKETPLYMOUTH SAPPOROPONTIACPORSCHERAMBLERRENAULTREOREO TRUCKRILEYROCHESTER UNIV PERFROVERSAABSEAGRAVESIMCASINGERSOLEX HI-PERF CARBSSPRINTSTERLING TRUCKSTEWART TRUCKSTUDEBAKERSTUDEBAKER TRUCKSTUTZSUBURUSUNBEAMSUZUKITERRAPLANETOYOTATOYOTA TRUCKTRIUMPHTVRVANDEN PLASVOLKSWAGENVOLKSWAGEN INDUST.VOLVOWARD-LAFRANCEWEBER HI-PERFORMANCEWHITE TRUCKWILLYS-OVERLANDWOLSELEYYUGOZENITH UNIVERSALmm_spacer.gif
space.png Years193819391940194119421943194419451946194719481949195019511952195319541955195619571958195919601961196219631964196519661967 Refresh
Always Check Your Carburetor Number for Accurate Kit Fitment
MACK TRUCK Other Models Years Models Manufacturer Type Numbers Kit 38-60 EN354A ENG ZENITH 28ADA10 3913
Copyright © 2014 Daytona Parts Co. Design by Larry Johnson .
